ZOI
Усилитель PowerBass asa-200.2
160$
+7 701 741 14 67
http://vse.kz/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=798694
http://vse.kz/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=798697
http://vse.kz/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=798695
4-ohm Power:
100 watts x 2
2-ohm Power:
200 watts x 2
4-ohm Mono Power:
400 watts x 1
Peak Power:
800 watts
Total Harmonic Distortion:
<0.05%
Frequency Response:
20Hz~22,000Hz
S/N Ratio:
>94dB
Damping Factor:
>150
Input Sensitivity:
0.5 - 4.0 volts
Crossover Slope:
12dB
High-Pass Crossover Freq (Hz):
40Hz~250Hz
Low-Pass Crossover Freq (Hz):
40Hz~250Hz
Variable Subwoofer EQ:
0/+18dB
Subwoofer EQ Frequency:
40Hz
Dimensions (in Inches):
10.2" x 9.3" x 1.9"
Берём американский усилитель)
